11-27-2006 12:23 PM
I cannont get my 2950 to reset to the factory default so I can run the Express setup on it. Any suggestions?
Solved! Go to Solution.
11-27-2006 12:35 PM
Do, "write erase", then "reload". The switch should reload on the factory, empty config.
11-27-2006 12:35 PM
11-27-2006 12:40 PM
Thanks for the info. I was finally able to find the configured address and have successfully accessed the switch.
