3640 continuouly rebooting
I have a 3640 router, which is continuously rebooting. When I break the booting process, it goes to the rommon mode. As long as it is in the rommon mode, it is fine. Otherwise it keeps on rebooting.
Can someone give me an advice how to stop this please?
Thanks in advance!
1 ACCEPTED SOLUTION
Re: 3640 continuouly rebooting
I don't think that the uploading of new IOS would solve the issue. You can try but the sure shot is the hardware issue.
Stanly Philip
the problem could be scarce RAM or faulty IOS or other. Could you please paste the console output here?
anton
Hi Anton,
Thanks a lot for your reply. I will paste the console output.
As I cannot past it in one post, I will paste the console output in several posts.
Thanks in advance!!
Omal
System Bootstrap, Version 11.1(19)AA, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Copyright (c) 1998 by cisco Systems, Inc.
C3600 processor with 65536 Kbytes of main memory
Main memory is configured to 64 bit mode with parity disabled
program load complete, entry point: 0x80008000, size: 0xd60590
Self decompressing the image : #################################################
############### [OK]
Smart Init is disabled. IOMEM set to:
Using iomem percentage: 10
Restricted Rights Legend
Use, duplication, or disclosure by the Government is
subject to restrictions as set forth in subparagraph
(c) of the Commercial Computer Software - Restricted
Rights clause at FAR sec. 52.227-19 and subparagraph
(c) (1) (ii) of the Rights in Technical Data and Computer
Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc.
170 West Tasman Drive
San Jose, California 95134-1706
Cisco Internetwork Operatin
IOS (tm) 3600 Software (C3640-JK9O3S-M), Version 12.2(17a), RELEASE SOFTWARE (fc
1)
Copyright (c) 1986-2003 by cisco Systems, Inc.
Compiled Thu 19-Jun-03 11:25 by pwade
Image text-base: 0x60008930, data-base: 0x615D6000
%ERR-1-GT64010: Fatal error, Parity error on master read
cause=0x0110E083, mask=0x0CD01F00, real_cause=0x00100000
bus_err_high=0x00000000, bus_err_low=0x31800000, addr_decode_err=0x14000470
r0 = FFFFFFFF r1 = FFFFFFFF r2 = 0 r3 = 621F0000 r4 = 0
r5 = 0 r6 = 0 r7 =
r10 = 0 r11 = 2 r12 = 0 r13 = 14 r14 = 0
r15 = F4240 r16 = 0 r17 = 625CE740 r18 = 0 r19 = 625CE73C
r20 = 0 r21 = 625CE738 r22 = 0 r23 = 625CE734 r24 = 0
r25 = 625CE730 r26 = 0 r27 = 625CE72C r28 = 0 r29 = 625CE728
r30 = 0 r31 = 625CE724 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFFF
r40 = FFFFFFFF r41 = FFFFFFFF r42 = FFFFFFFF r43 = FFFFFFFF r44 = FFFFFFFF
r45 = FFFFFFFF r46 = FFFFFFFF r47 = FFFFFFFF r48 = 0 r49 = 625CE79C
r50 = FFFFFFFF r51 = FFFFFFFF r52 = 0 r53 = 3041F001 r54 = 0
r55 = 100000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 624BA148
r60 = FFFFFFFF r61 = FFFFFFFF r62 = 0 r63 = 61214504
sreg = 3401E103 mdlo_hi = 0 mdlo = 9C4
mdhi_hi = 0 mdhi = 0 badvaddr_hi = FFFFFFFF
badvaddr = FFFFFFFF cause = FFFFFFFF epc_hi = 0
epc = 6121455C err_epc_hi = FFFFFFFF err_epc =
%ERR-1-FATAL: Fatal error interrupt, reloading
err_stat=0x10
=== Flushing messages (00:00:09 UTC Mon Mar 1 1993) ===
Queued messages:
Queued messages:
00:00:07: %CPM-3-INCORRECT_ID: CPM at slot 0: PCI device not supported
00:00:07: %AMDP2_FE-3-NOTAMDP2: Slot 0 device ID seen as 0x0, expected 0x2000102
00:00:07: %CPM-3-DISCOVER: CPM at slot 0: PCI discovery failed count = 0
*** System received a System Error ***
signal= 0x16, code= 0x0, context= 0x624a
PC = 0x6039ff30, Cause = 0x20, Status Reg = 0x34018002
Smart Init is disabled. IOMEM set to: 10
cisco Systems, Inc.
1)
r5 = 0 r6 = 0 r7 = 15D9C30C r8 = 0 r9 = 3
r55 = 30410000 r56 = FFFFFFFF r57 = FFFFFFFF r58 = 0 r59 = 624BA148
epc = 6121455C err_epc_hi = FFFFFFFF err_epc = FFFFFFFF
err_stat=0x10
Queued messages:
signal= 0x16, code= 0x0, context= 0x624a15a8
cisco Systems, Inc.
1. Remove all NM cards, reboot..
00:00:07: %CPM-3-INCORRECT_ID: CPM atslot 0: PCI device not supported
2. If prob. still there, re-post your new console log. There could be memory ( wrong type / mis-match ) .
Seem to be hardware related for sure.
HTH, locp
Could you please tell me how to remove the NM cards? Do I have to remove the cover of the router or can I remove the NMs without removing the cover?
Please let me know.
Thanks in advance!
Thanks a lot for helping me to sort out my issue. The problem was with my NM like you said.
Once it booted then I typed a "show version" and "show run" but I did not see the interfaces that were connected to a particular slot. Then I removed it from there and plugged to a different slot. Then it worked perfectly.
Thank you once again!!!!
1)
err_stat=0x10
Queued messages:
Bronze
Hii,
pls check with the errors the router is generating as this could be a bug which is forcing the router to reboot.pls post the sh ver config ...
The problem is the router does not come to the following mode:
Router>
Instead it keeps on restarting. I think it boots up to the last point before it goes to the setup mode, and then restarts without going to the setup mode.
I have pasted what ever the output that I'm getting, above.
Please help me to sort it out.
Thanks in advance!
Bronze
Hii,
from the o/p pasted it seems there is some ios issue which is not allowing it to find the correct bootup point,i.e.the bus points to some wrong mem positions.
Try erasing ur router configs and then reload it to check if the same occurs.if it doesnt help then try to reload a newer version of IOS for this platform which will solve the issue.
Pls let me know / rate if it helps.
3640_2 uptime is 1 minute
System returned to ROM by error - a System Error, PC 0x603DDF74
System image file is "flash:c3640-jk9o3s-mz.122-17a.bin"
3640_2#show stacks
Minimum process stacks:=0x0110E083, mask=0x0CD
Free/Size Name0x00100000
22180/24000 CCSIP_UDP_SOCKET
bus_err
4180/6000 DHCPD Receiveow=0x31800000, addr_decode
9596/12000 Init
5444/6000 PostOfficeNet
5436/6000 RADIUS INITCONFIGFF r2 = 0 r3 = 621F00
Interrupt level stacks:
Level Called Unused/Size Name= B r6 = FFFFFFFF r7 = B
1 1713 8288/9000 Network interfaces
2 0 9000/9000 DMA/Timer Interrupt13 = 0 r14 = 0
3 0 9000/9000 PA Management Int Handler r16 = 0 r17 = C100 r18 = 0 r19 = 34
4 628 8584/9000 Console Uart
r2
5 0 9000/9000 External Inte
System was restarted by error - a System Error, PC 0x603DDF74 r31 = 625CE6C0 r32 = FFFFFFFF r33 = FFFFFFFF r34 = FFFFFFFF
3600 Software (C3640-JK9O3S-M), Version 12.2(17a), RELEASE SOFTWARE (fc1)r35 = FFFFFFFF r36 = FFFFFFFF r37 = FFFFFFFF r38 = FFFFFFFF r39 = FFFFFFF
Compiled Thu 19-Jun-03 11:25 by pwade (current version)
Stack trace from system failure:
FP: 0x624BA130, RA: 0x603DDF74
FP: 0x624BA160, RA: 0x603DCF30
FP: 0x624BA180, RA: 0x60035530
FP: 0x624BA1B0, RA: 0x60031CD0
FP: 0x624BA1D8, RA: 0x603DA714
FP: 0x624BA218, RA: 0x603DA818
FP: 0x624BA230, RA: 0x60395548
FP: 0x624BA258, RA: 0x602D2BE4
******* Information of Last System Crash **********
Using flash:crashinfo.
%Error opening flash:crashinfo (No such file or directory)
3640_2#
3640_2#show context
Well, I am unable to give any command as it keeps on rebooting. But I will try what you have said below, which is uploading a new IOS. That'll be a good move.
I will try this when I go to work tomorrow :)
Thank you so much!
Omal
Bad memory. I've had this a couple different times and it was always bad hardware.
Are you sure you have the proper amount of memory to boot the version of code you have?
Yes, because this router had been using in a different location.
But it could be a hardware problem becuase it was brought from another country. So I'm not sure if anything damaged on the way.
Stanly Philip
Hi Stanly
Thank you so much for your post. It stopped rebooting. Therefore I could give some commands and get some output, which I posted above. Hope you will be able to get some idea from that and tell me what has gone wrong in my router.
Thanks in advance!
Thank you very much everyone for helping me to solve my problem. It was a hardware problem. I removed the NM from the slot it was connected to and plugged to a different slot and it worked.
Many thanks to everyone again!!!!
586
