3750 Chassis Alarm for RPS
Does anybody know if 3750 sets chassis alarm when using RPS?
I'm trying to monitor when my 3570-48ps switch stack has power problems and is using RPS.
I assumed when switch was using RPS it would set chassis minor or major alarm.
1 REPLY
Bronze
Re: 3750 Chassis Alarm for RPS
I think use the show env user EXEC command to display fan, temperature, redundant power system (RPS) availability, etc?
For more information please click following URL:
http://www.cisco.com/en/US/docs/switches/lan/catalyst3560/software/release/12.2_20_se1/release/notes/OL554704.html
However bear in mind The 3750 platform does not have support for temperature monitoring. It doesn't have hw capabilities to do so. It just has preset max temperatre settings which is max temp. supported. As far as temperature is below that it displays "Temperature is OK" in show env all output.
460
