3825 SNMP monitoring - MGCP PRI D-channel state?
Apologies in advance for cross-posting this but I realized after I made the initial post that I'd probably placed it incorrectly.
I'm desperately trying to find a way to retrieve the D-channel state for our voice PRI's. Two days of poking about on Cisco's site has provided no answers. Can someone point me in the direction of an OID that will retrieve the D-channel status? What should the values be for 'up' and 'down'?
Thanks in advance for any assistance you can provide.
Re: 3825 SNMP monitoring - MGCP PRI D-channel state?
Not sure what kind of device you want to monitor this on, but have at look at these objects:
.1.3.6.1.4.1.9.10.19.1.5.2.1.1
cpmDS0OperStatus OBJECT-TYPE
-- FROM CISCO-POP-MGMT-MIB
SYNTAX Integer { unknown(1), down(2), idle(3), setup(4), connected(5), test(6) }
MAX-ACCESS read-only
STATUS Current
DESCRIPTION "The operational state of the DSO.
This object provides more detailed information than
the IF-MIB ifOperStatus.
unknown - The DSO is in an unknown state
down - The DS0 is out of service
idle - This DS0 is currently idle
setup - A new connection is in the process
of being established
connected - A active connection exists
test - The DSO is undergoing internal testing
.1.3.6.1.2.1.10.20.1.3.4.1.2
isdnLapdOperStatus OBJECT-TYPE
-- FROM ISDN-MIB
SYNTAX Integer { inactive(1), l1Active(2), l2Active(3) }
STATUS Current
DESCRIPTION "The operational status of this interface:
inactive all layers are inactive
l1Active layer 1 is activated,
layer 2 datalink not established
l2Active layer 1 is activated,
layer 2 datalink established."
Thanks Davistan. I wound up using ifOperStatus (1.3.6.1.2.1.2.2.1.8) and figuring it out from there.
Appreciate you taking the time to respond. :)
Yup...ifOperStatus or ifAdminStatus will do it too if you are just looking for basic interface up/down
606
