4500 SNMP Module alarms traps
I am trying to find the correct configuration for when modules from 4500 series devices are removed or fail an SNMP trap will be sent.
So far I can not find any documentation or supporting command that will trigger this.
The command on the 6500 series does not exist on the 4500s.  " snmp-server enable traps module "
Version:
Cisco IOS Software, Catalyst 4500 L3 Switch Software (cat4500-IPBASEK9-M), Version 12.2(53)SG, RELEASE SOFTWARE (fc3)
Please help, Thank You!
Everyone's tags (6)
1 ACCEPTED SOLUTION
Re: 4500 SNMP Module alarms traps
I believe you have "snmp-server enable traps fru-ctrl".  That should enable the cefcModuleStatusChange traps which will be sent when a module changes state.
Thanks!
The command originally didn't work by itself, but after come changes to the other SNMP configurations the traps were then received.
SNMP configurations below:
Switch#show run | inc snmp
snmp-server community (removed) RW 5
snmp-server trap-source Vlan411
snmp-server chassis-id (Removed)
snmp-server enable traps entity
snmp-server enable traps envmon fan temperature
snmp-server host *.*.*.* (Removed)  fru-ctrl envmon
Logging:
Switch#show run | inc log
service timestamps log datetime localtime
logging buffered 16384
logging trap notifications
2593
