6504E : CiscoView Device Manager / Embedded CiscoView possible ?
Dear all,
we have a Catalyst 6504E (from the ACE20 4G 6504E Bundle with Sup720-3B), which we want to manage using the web interface. Unfortunately we don't get "CiscoView Device Manager" and "Embedded CiscoView" running. We do know that the 6504 is not mentioned in the CVDM's release notes. Is there a trick to use it anyway ?
Thanky you very much in advance.
  • Network Management
1 REPLY
Re: 6504E : CiscoView Device Manager / Embedded CiscoView possib
CVDM is no longer being developed, and will not work with this device. For visual management, you would need CiscoWorks LAN Management Solution with CiscoView.
124
