Community Member
6509-E VSS Not recognised by Network Node Manager
Hello, I am having trouble getting NNM8.10 to "recognise" our two 6509-E set up as a VSS pair. The Device shows as Cisco generic device. Other 6509-E (non VSS) devices are discovered correwctly. All SNMP strings are correct. I'm assuming this is a MIB or OID problem? Does anyone know the specifiv MIB which will correctly identify the device? I'd hate to think I would need to download any install every 6500 MIB!
Thanks in advance.
137
