Community Member
6509 not showing in Ciscoview
I have ciscoview 6.1.8 with lms 3.1. I upgraded 3.1 from 3.0 & 3.0.1 But from the begining I am not able to see the chassis view of 6509.
Pls advise
Sachi
Hall of Fame Super Silver
Re: 6509 not showing in Ciscoview
Have you downloaded and installed the latest Package Device Update for the Catalyst 6000 series? To do this, follow the User Guide steps, excerpted here:
"Step 1 From the Common Services tab in the CiscoWorks LMS Portal, select Software Center > Device Update.
The Device Updates page appears.
Step 2 Select the check box corresponding to the product for which you want to check for updates and click Check for Updates."
I assume that the RME etc. functionality is working with your 6509(s), so we are not dealing with a reachability, credentials or transport protocol issue here.
Community Member
Everything else is working fine.
Device package is there. Even I tried deleting the existing package tomcat & copied again from psu thinking that the package might curropted but still its not working.
Sachi
Community Member
Hi All,
Can anybody pls advise why I am not able to see 6509 in the cisco view.
Sachi
Community Member
I also had this problem with packages Cat6000.zip. Cat6000IOS.zip installed. Then I tried to update devices automaticaly and noticed that despite those packages CiscoView also needs CVGenericPackage.zip to be installed. Try this hopefully it will help you.
172
