10-25-2007 12:16 PM
I have a 6509 switch running vers 12.2.
I seem to have lost management to the switch ping/telnet access. The switch is working and i'm able to console. Does anyone know why, or how I can fix this?
Thanks.
10-25-2007 05:33 PM
You must have already checked your PC's LAN connection, haven't you?
Please look if the management vlan/IP is still there and operational. Check it's vtp status etc..
10-25-2007 11:43 PM
If your manage you switch on a vlan interface check if you can define a port of the switch in the same vlan and connect a pc with an IP in the same range as the IP of switch to that port.
Cheers,
Michel
10-26-2007 03:30 AM
Besides the VLAN access, have you checked for an ACL that could be blocking VTY access?
Steve
