Blue
7200 routers sending generic Agent Interface Down traps
Does anyone know why the 7200s would be sending generic "Agent Interface Down (linkDown)" traps (.1.3.6.1.6.3.1.1.5.3) rather than "Cisco Agent Interface Down (linkDown)" traps (.1.3.6.1.6.3.1.1.5.3.1.3.6.1.4.1.9.1.ifIndex#)?
Re: 7200 routers sending generic Agent Interface Down traps
What version of IOS, and what does your SNMP config look like? If you have:
snmp-server trap link ietf
Then it will send standard link trap.
Blue
>sh ver
Cisco IOS Software, 7200 Software (C7200-A3JK9S-M), Version 12.4(8b), RELEASE SOFTWARE (fc2)
I don't see ietf configured, just:
snmp-server enable traps snmp authentication linkdown linkup coldstart warmstart
This was changed recently so that the link traps will be sent from 1.3.6.1.6.3.1.1.5. However, there should still be an additional varbind at the end of the trap, locIfReason, which gives the reason the interface state changed.
I just confirmed your code is recent enough to have these changes. Basically, all linkUp traps will have the OID snmpTraps.4, and all linkDown traps, snmpTraps.3. Depending on whether or not you enable IETF link traps, the varbinds will change. The Cisco (i.e. non-IETF varbinds) are:
ifIndex
ifDescr
ifType
locIfReason
The IETF varbinds are:
ifIndex
ifAdminStatus
ifOperStatus
ifDescr
ifType
locIfReason
If this interface has a cciDescr (i.e. this is a circuit interface) the traps will contain the following varbinds. Cisco:
ifIndex
ifDescr
ifType
cciDescr
locIfReason
IETF:
ifIndex
ifAdminStatus
ifOperStatus
ifDescr
ifType
cciDescr
locIfReason
So, enabling the IETF link traps will give you more information in the body of the trap.
Blue
Does enabling the IETF option always make the linkDown trap more informative across all platforms (7200 vs 6500, etc.)?
Yes, provided the IOS supports enabling this option. The "snmp-server trap link ietf" command was added in 12.1(2)T.
656
