7206VXR and VPN
I would like to know if there is any limit of site-to-site VPN connections per a 7206?
And if yes, how many?
Thanks for your help,
Mehdi
1 ACCEPTED SOLUTION
Re: 7206VXR and VPN
VSA is the new name for VAM. If you do a show inventory, the VSA shows up as SA-VAM2+
Re: 7206VXR and VPN
Re: 7206VXR and VPN
Thanks for your help.
Re: 7206VXR and VPN
Is there any command that I can use to find out if there is VSA installed on the router or not?
I know that there is a VAM but not sure about VSA.
Re: 7206VXR and VPN
Re: 7206VXR and VPN
Awesome, thanks alot.
225
