7507 Netflow - no flows showing up for specific port
I have a 7507 with IOS (tm) RSP Software (RSP-K4PV-M), Version 12.0(32)S5, RELEASE SOFTWARE (fc2.
I have "ip route-cache flow input" enabled on several ports but when I view "sho ip cache flow" I only see flows from certain ports.
In particular there is a VIP4-80 with a PA-GE in slot 6 that has 6Megs of inbound traffic, yet no flows appear. CEF distributed is enabled globally.
Is there something I need to do to see flows for this port?
Thank you,
Bryan
Re: 7507 Netflow - no flows showing up for specific port
Do you get an error message when you enable cef distributed such as:
SFGECISSF1/sf1(config)#ip cef dist
SFGECISSF1/sf1(config)#^Z
SFGECISSF1/sf1#
%SYS-5-CONFIG_I: Configured from console by console
%IPC-5-SLAVELOG: VIP-SLOT12:
%IPFLOW-2-CACHEINIT: Error initializing IP flow cache
In that case you would be hitting bug: CSCdt07408
Else can you post your outputs of the configuration and the show ip cache flow?
DCEF is already running. There is no error when you re-enable it. Here is some oputputs:
interface GigabitEthernet6/1/0
ip address x.x.x.x 255.255.255.252
no ip redirects
no ip unreachables
no ip directed-broadcast
no ip proxy-arp
load-interval 30
negotiation auto
xxxxxx#sho int g6/1/0 | inc rate
Queueing strategy: fifo
30 second input rate 8854000 bits/sec, 2707 packets/sec
30 second output rate 27809000 bits/sec, 3535 packets/sec
xxxxxxxxxxxxx#sho ip cache g6/1/0 flow | beg Src
SrcIf SrcIPaddress DstIf DstIPaddress Pr SrcP DstP Pkts
Gi6/1/0 x.x.x.x Local x.x.x.x 06 00B3 88BC 2
Only that local flow shows up for g6/1/0. There are several other flows on a serial interface of this router that show up.
369
