Webcast-Catalyst9k
871, SDM default rules not appearing
Hi I recently bought a new 871.
It seems to work fine, but I am having some trouble with SDM 2.2 - when I try to create an advanced firewall, I am unable to select anything except for SDM_Low....the slider appears, but SDM_Medium and High are grayed out and unselectable.
I have pasted the output from show version below.
Has anyone seen this before and if so how did you solve this?
I have contacted Cisco and an engineer was able to reproduce this, but they have been slow to respond and I would like to know whats going on. In and of itself this iss not a huge deal, I can create my own inspection rules, but if this isnt working it makes me wonder if other things arent working correctly also.
Thanks in advance for your help,
Mike
Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
Synched to technology version 12.3(10.3)T2
Copyright (c) 1986-2005 by Cisco Systems, Inc.
Compiled Tue 14-Jun-05 18:58 by ealyon
ROM: System Bootstrap, Version 12.3(8r)YI2, RELEASE SOFTWARE
ROM: Cisco IOS Software, C870 Software (C870-ADVIPSERVICESK9-M), Version 12.3(8)YI2, RELEASE SOFTWARE (fc1)
router uptime is 5 hours, 19 minutes
System returned to ROM by reload at 15:08:46 PCTime Sun Feb 26 2006
System restarted at 15:06:52 PCTime Sun Feb 26 2006
System image file is "flash:c870-advipservicesk9-mz.123-8.YI2.bin"
Last reload reason: Reload command
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 871 (MPC8272) processor (revision 0x200) with 118784K/12288K bytes of memory.
Processor board ID FHK100320UX
MPC8272 CPU Rev: Part Number 0xC, Mask Number 0x10
5 FastEthernet interfaces
128K bytes of non-volatile configuration memory.
28672K bytes of processor board System flash (Intel Strataflash)
1 REPLY
Silver
Re: 871, SDM default rules not appearing
not sure of the issue, may be you can check out the following link for troubleshooting :
http://www.cisco.com/en/US/products/sw/secursw/ps5318/products_user_guide_chapter09186a0080500af4.html
193
