A way to get OSPF events on CW LMS...
Hi guys,
I need to have OSPF events/traps to appear on CW in some way, but OSPF traps are not supported in DFM.
Is there any way to extened DFM capabilities (like using RME - syslog for instance)
Apreciate your help,
Pedro Trigueira
Re: A way to get OSPF events on CW LMS...
RME may be a good alternative depending on the IOS version you have. For IOS 12.4, here is a link to the various OSPF-related syslog messages:
http://www.cisco.com/univercd/cc/td/doc/product/software/ios124/124sup/124sms/124smsv2/sm_22h.htm#wp429297
You can then use the RME Automated Action feature to turn these messages into email messages or whatever you need for further notification.
Is it possible in RME to turn theses messages into traps ?
P
Yes, you could do it, but not out-of-the-box. You could create an automated action script that calls Net-SNMP's snmptrap command to create a corresponding OSPF trap, or build a custom trap of your own design.
The Net-SNMP suite can be found at http://net-snmp.sourceforge.net .
131
