AAA on 3750
How to disable AAA on 3750 switch which has got screwed up due to missing of tacacs-server key command in older configuration. I believe RMON mode will not work...
Re: AAA on 3750
Just bypass loading the configuration and then use "no aaa new-model".
http://www.cisco.com/en/US/products/hw/switches/ps628/products_password_recovery09186a0080094184.shtml
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
Re: AAA on 3750
Or, you could simply remove the device from the NDG on the ACS server so the server doesn't recognise it, then login with your local username/password; assuming you set one for this type of eventuality....:-))
94
