AAA RADIUS authentication on switches
I have in the past configured switches to use TACACS+ for security on telnet sessions. Can I use RADIUS for the same thing?
Red
Re: AAA RADIUS authentication on switches
Yes, you may use RADIUS for the same thing.
There are a number of sample configurations located at:
http://www.cisco.com/en/US/tech/tk59/tech_configuration_examples_list.html
Is there a similar link but for a switch running IOS not CatOS?
Check out this link:
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a00800ca7ab.html#wp1001359
Just want to add, for router management TACACS+ is a better choice than radius. Radius doesn't give you the ability to specify which commands can or cannot be executed in the router by a user.
Hope this helps!
Sundar
Thanks Sundar but my mgmt here won't purchase a TACACS+ server.
105
