Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Access-list for snmp on Nexus1000V
Hello everyone!
I am new to Nexus1000V and I  was wondering if there is a way to limit snmp access via access-list on  the RO/RW community, as can be done on IOS.
I can't find anything relevent on the Reference Pages, so I was curious if anyone has done this...
Thanks in advance,
Katerina
Hi Katerina
Yes.. You should be able to define ACL's as with other NX-OS devices... This is what I saw in our device:
VSM(config)# snmp-server community abc ?
  group    Group to which the community belongs
  ro       Read-only access with this community string
  rw       Read-write access with this community string
  use-acl  Acl name to filter snmp requests
you can first define the comunity abc as read-only, and then apply the same command with use-acl with access-list name/number attached to it.
Hope this helps..
Raj
Hello Raj and thanks for your reply
We only get:
MKBE1NX1(config)# snmp-server community xxxx?
No acl to configure
What NX-OS are you running? We have 4.2(1)SV1(4).
Thanks!
switch(config)# ip access-list CiscoACL
switch(config-acl)# permit ip any any
switch(config)# snmp-server community cisco rw
switch(config)# snmp-server community cisco use-acl CiscoACL
Obviously you can restrict to any host you like but this is simplistic example to get you started.
486
