Accessing 3560 switch from other subnet.
Hi all.
Im trying to find the solution to allow other subnets that then local one to access my switch. Im currently located on another net that the switch but i can access it via ip.
When i try to access it via telnet or ssh, i get no aswers. If i do it from the same net it works. I found a command called permit but is seems not to exist on my new switch.
Thanks in advance.
p
1 ACCEPTED SOLUTION
Re: Accessing 3560 switch from other subnet.
Your switch has no layer 3 configuration, but it has the "ip routing" command, and thus please use "no ip routing" in order to gain the use of the "ip default-gateway 10.0.5.1" command, as if i am assuming correct the "10.0.5.1" is your LAN gateway which shall do the remote access job for you.
HTH, please do rate all helpful replies,
Mohammed Mahmoud.
If you post your config and type in what ip address's we can can help you out.
Couple of things might be happening there might be an ACL blocking or permitting only certain subnes from managing your switch, or the subnet your on is not being routed to the subnet that your switchs SVI interface is on.
Patrick
Hi again. Thanks for replying!
I forgot to say that i can't get any syslogs from the switch, switch on net 10.0.5.0/24, im on 10.0.8.0/24.
Im new to Cisco so maybe my questions are noobish but how can i see which layer the switch is operating in? I presume its layer 2 now.
I post my config (show run-command right?):
version 12.2
no service pad
service timestamps debug uptime
service timestamps log uptime
hostname switch_vaning-5
logging count
logging console warnings
enable secret xxx
enable password xxx
username silvesurfer password xxx
no aaa new-model
vtp mode transparent
ip subnet-zero
ip routing
no file verify auto
spanning-tree mode pvst
vlan internal allocation policy ascending
interface GigabitEthernet0/1
description Tele2-LAN
switchport mode access
spanning-tree portfast
interface GigabitEthernet0/2
description F&B_LAN-VANING-5
interface GigabitEthernet0/3
interface GigabitEthernet0/4
interface GigabitEthernet0/5
description Backup
interface GigabitEthernet0/6
description Backup_harddisk
interface GigabitEthernet0/7
description Telefonboken
interface GigabitEthernet0/8
description Mediabank_temp
interface GigabitEthernet0/9
description ftp
interface GigabitEthernet0/10
description agda
interface GigabitEthernet0/11
description -untitled-
interface GigabitEthernet0/12
description .
interface GigabitEthernet0/13
description ARKIV-WEB
interface GigabitEthernet0/14
description ARKIV-SQL
interface GigabitEthernet0/15
description MULTISERVER
interface GigabitEthernet0/16
description BIGBROTHER
interface GigabitEthernet0/17
description ns.intern-en0
interface GigabitEthernet0/18
description ns.intern-en1
interface GigabitEthernet0/19
description .
interface GigabitEthernet0/20
description support
interface GigabitEthernet0/21
description HALON_PRIMARY
interface GigabitEthernet0/22
description HALON_SECONDARY
interface GigabitEthernet0/23
interface GigabitEthernet0/24
description .
interface GigabitEthernet0/25
description CITYAKUTEN-1
interface GigabitEthernet0/26
description CITYAKUTEN-2
interface GigabitEthernet0/27
interface GigabitEthernet0/28
interface Vlan1
ip address 10.0.5.218 255.255.255.0
ip classless
ip http server
logging facility local2
logging 10.0.8.184
snmp-server community xxxx RO
control-plane
line con 0
line vty 0 4
password xxxxx
no login
line vty 5 15
password xxxxx
no login
monitor session 1 source interface Gi0/21
monitor session 1 destination interface Gi0/18
ntp server 17.254.0.27
end
Thx again.
Mohammed Mahmoud.
Thousands thanks!
Solved my problem.
p
You are very welcomed, and thanks for using the rating system.
BR,
Mohammed Mahmoud.
Hello again.
This is strange for me, the "trick" worked on one of my three switches so naturally i wonder whats wrong with the other two, posting my config and hoping you could help me once again:
Switch02#sh run
Building configuration...
Current configuration : 2302 bytes
version 12.2
no service pad
hostname Switch02
enable secret xxx
enable password admin
no aaa new-model
ip subnet-zero
no file verify auto
no spanning-tree vlan 1
description .
interface GigabitEthernet0/29
interface GigabitEthernet0/30
interface GigabitEthernet0/31
interface GigabitEthernet0/32
interface GigabitEthernet0/33
interface GigabitEthernet0/34
interface GigabitEthernet0/35
interface GigabitEthernet0/36
interface GigabitEthernet0/37
interface GigabitEthernet0/38
interface GigabitEthernet0/39
interface GigabitEthernet0/40
interface GigabitEthernet0/41
interface GigabitEthernet0/42
interface GigabitEthernet0/43
interface GigabitEthernet0/44
interface GigabitEthernet0/45
interface GigabitEthernet0/46
interface GigabitEthernet0/47
interface GigabitEthernet0/48
interface GigabitEthernet0/49
interface GigabitEthernet0/50
interface GigabitEthernet0/51
interface GigabitEthernet0/52
interface Vlan1
ip address 10.0.5.219 255.255.255.0
ip classless
ip http server
control-plane
line con 0
line vty 0 4
password xxxxx
no login
line vty 5 15
password xxxxx
no login
end
Thx!
p
Hi for the last time. : )
Solved it myself, no default gateway.
p
You are very welcomed, and i am very glade that you've been an expert in this stuff now :)
HTH,
Mohammed Mahmoud.
He-he, yes, one down, a thousened to go.. : )
I love playing with Cisco a lot, so much to do, its just the beginning..
p
To access the switch from another subnet, its a routing issue, if the switch is acting as layer 2 (no ip routing) you should use the "default-gateway" command (where the local subnet router should be the default gateway), if it is acting as a layer 3 switch you must make sure that the subnets that you are trying to access the switch from is routable to the switch.
Mohammed Mahmoud.
175
