Community Member
Accessing resouces with local IP using public IP
I am using a PIX 506E version 6.3(5) using 10.0.0.X. We recently installed a voice mail server with the ip address 10.0.0.92 and I set up a static IP map for address 66.x.x.x to allow access from the outside.
My issue is that we have laptops that are sometimes inside and somtimes outside.
Is there a way to use the public IP address (66.x.x.x) inside the local network and route it to the device's ip address (10.0.0.92)?
1 REPLY
Silver
Re: Accessing resouces with local IP using public IP
You can use NAT It will translate the public ip to private ip.
http://www.cisco.com/en/US/tech/tk648/tk361/technologies_tech_note09186a0080094e77.shtml
127
