09-19-2005 10:11 PM
Does anyone have the URL and login details for the Web interface to the Sybase DB?
I have corrupt syslog entries that need to be groomed out. This has caused SYSLOG to stop collecting.
Cheers,
MM
09-20-2005 03:41 AM
Which version of RME are you running? On what platform?
09-20-2005 02:58 PM
It is run on Windows and is version 3.4
09-20-2005 03:09 PM
What is the size of your CSCOpx\log\syslog.log file?
09-20-2005 04:20 PM
Do you know of the URL that I am referring to? If you dont it's Ok. I will raise a TAC case.
09-20-2005 05:24 PM
Yes I do. You need to login as admin first, then go to:
http://server:1741/dbreader/dbreader.html
I suspect that your syslog.log might be large and that is what is causing the issue
09-21-2005 04:50 PM
Thanks for the URL the username and password are as follows:
username: dba Password: c2ky2k
you will also require the Database such as 'rme'
