Webcast-Catalyst9k
ACL configuration and tracking management
What sofware or system would you suggest to manage configuration and tracking of ACLs on a number of Cisco devices?
1 REPLY
Silver
Re: ACL configuration and tracking management
I thought everyone used ACL Manager to manage ACL's configuration & Tracking.
ACLManager recognizes and tracks all existing types of ACL uses (such as router, route-map, and crypto-map). This means that if you rename an ACL that is referenced in uses other than traffic filtering or line access, the use statement is updated with the new ACL name.
Network problems are frequently introduced when devices are configured, and fixing such problems is both expensive and time-consuming. Also, since router/switch configurations are interdependent, network complexity increases exponentially with the number of routers, and configuration problems become harder to detect and avoid.
The result is either operational or latent configuration problems. ACL Manager solves these problems by providing inventory and change audit features that simplify the processes for setting up and changing device configurations.
For further information click this link.
http://www.cisco.com/en/US/products/sw/cscowork/ps402/products_user_guide_chapter09186a00801fceab.html#wp24468
124
