ACNS 5.1.3
I am not sure if this is the correct forum, if not I apologize. This is my first Netpro question and I am thoroughly confused at this point.
Synposis: I have in my position several 507 content engines with CE ver 2.51. These are from 02 or so, old yes, but my orders are to upgrade them to CE507-5.1.3. My problem is I cannot find it! I have looked through every upgrade document and sifted through the software repository. I don't know if I'm missing it or what, but I am in need of assistance if someone is knowledgeable in this situation. I would greatly appreciate it.
1 REPLY
Re: ACNS 5.1.3
If you have CCO software download access you can get the software from here:
http://www.cisco.com/cgi-bin/tablebuild.pl/acns51
Just in case you need the upgrade procedure check the following URL:
http://www.cisco.com/univercd/cc/td/doc/product/webscale/uce/acns50/deploy50/50upgrd.htm#1041008
225
