09-15-2014 10:54 PM
Hi All,
Facing issue mentioned below
created two NDG with switches and Coreswitches.
Than created two access rule
Rule 1 with NDG as Switches
Rule 2 with NDG as coreswitches.
Acs is intergarted with AD.
Devices under NDG type switches works absoutely fine.
Devices under NDG type coreswitch gives command authorization failed (username get autheticated)
When the devices are moved to NDG switches everything works fine.
09-15-2014 11:57 PM
Hi ,
check the privileges level set for the group "coreswitches" , it should be level 15.
Thanks-
Afroz
***Ratings Encourages Contributors ***
09-16-2014 12:37 AM
It is already 15
