Community Member
ACS showing high CPU after changing ip add on appliance
Initially two acs were in pri and sec was working fine. We had change the location of secondary and then it is in different subnet. We had change the ip address and host name of the device. Now we are facing a high cpu utilization and no authentication is happen.
Will it be working by changing ip address of appliance or again i have to reconfigure it.
Pl suggest as early
Thanks and Regards.
197
