Community Member
ACS v3.3 XML Schema error
When I click shared profile components> Ciscoworks campus manager> and any name (Approver, helpdesk, Network Admin, Network Operator, or system Admin) I get the following error.
"XML Schema for this service type is not installed. Please reinstall this service type which should properly install the XML Schema as well."
The other ciscoworks components (CS, DFM, RME, IPM, and CiscoView) work fine.
I have already tried to rebooting the server with no luck.
1 REPLY
Silver
Re: ACS v3.3 XML Schema error
Problem with shared profile components
Go to LMS and go to under
CommonServices->Server->Admin->Licensing. What do you see there? If you
can, please reapply your license file again. After that, please try this:
1. Turn the mode back to local in LMS.
2. Log out from LMS.
3. Log in using the user "admin"
4. In the ACS, clear the services again.
5. Register again.
302
