Add a device type in LMS2.5.1
Ciscoworks LMS2.5.1 is not able to backup the config of a 4506e. The following error message is generated:
>>>> CM0056 Config fetch failed for <hostname> Cause: CM0204 Could not create DeviceContext for 2762 Cause: CM0206 Could not get the config transport implementation for <IP> Cause: UNKNOWN Action: Check if required device packages are available in RME. Action: Check if protocol is supported by device and required device package is installed. <<<<<
How do i add the 4506e device type to RME?
Thanks!
1 REPLY
Re: Add a device type in LMS2.5.1
If you upgrade to LMS 2.6, then to LMS 2.6 SP1 (i.e. RME 4.0.6), then you can download the device package for the 4500-E switches. This package was just released eight days ago. All of these updates are freely available from Cisco.com. Start from http://www.cisco.com/kobayashi/sw-center/cw2000/lan-planner.shtml to get the LMS 2.6 update.
101
