Add device to IPM on LMS 4.1
Hi all,
I have accidentally deleted a device from IPM. How can I re-add it? Do the IPSLA Devices somehow get sync-ed with the devices in DCR.
If I use the option "Add adhoc target" will the result be the same?
Thanks in advance,
Katerina
1 REPLY
In order for the device to reappear in IPM I had to delete it from RME and re-add it (either manually or by the discovery). This however resulted in losing any info that was previously gathered about this device (config archive, syslog, etc). This is what I wanted to avoid.
Does any one know of another way to sync IPM with DCR?
Thanks in advance,
Katerina
350
