Adding Cisco 6505 to CNA
I am using CNA ver 5.3 and can't seem to add several 6505's to my community. When I try to add it comes back with a "cannot connect" error. I can telnet into both 6505 without any trouble at all. I would like to add these since they are the core routers and I would like to see the links to them.
Thanx,
Mark
Re: Adding Cisco 6505 to CNA
Can you access those IP addresses using browser on the CNA PC ? Is HTTP/HTTPS enabled ?
It appears that I cannot access either router through the browser.
Mark
it is possible that http access is either not turned on at all or maybe other security settings that block http ?
178
