Adding Devices (SNMPv3) - Cisco LMS 2.6
Hello everybody!
I'm having problems adding devices in Cisco LMS. Those devices are using SNMPv3. Everything seems to be working normal when I execute
snmpwalk -v 3 -u ciscolms -l authPriv -a MD5 -A ciscolms -X ciscolms XXX.XXX.XXX.XXX
However, when I add a device in LMS, it is placed in "Questioned" devices, and the following debug message is received:
Aug 6 14:34:53: SNMP: Get request, reqid 67181, errstat 0, erridx 0
system.1.0 = NULL TYPE/VALUE
system.2.0 = NULL TYPE/VALUE
system.4.0 = NULL TYPE/VALUE
system.5.0 = NULL TYPE/VALUE
system.6.0 = NULL TYPE/VALUE
Aug 6 14:34:53:
Incoming SNMP packet
Aug 6 14:34:53: v3 packet security model: v3 security level: auth
Aug 6 14:34:53: username: ciscolms
Aug 6 14:34:53: snmpEngineID: 8000000903000019E8AC3290
Aug 6 14:34:53: snmpEngineBoots: 1 snmpEngineTime: 602068
Aug 6 14:34:53: SNMP: Response, reqid 67181, errstat 16, erridx 0
Could you please tell me what might be causing the problem?
Best Regards,
Vladislav Vasilev
Silver
Re: Adding Devices (SNMPv3) - Cisco LMS 2.6
Hi Vladislav,
authpriv will maybe not supported in LMS 2.6 and is still not supported in LMS 3.0. For LMS 3.0 there will be a patch coming until the end of this year.
Until then use AuthNoPriv.
Hope that helps.
Best regards,
Frank
Hello Frank,
Thank you very much for your prompt reply!
It's working now :)
Best Regards,
Vladislav
840
