Attention: The Community will be in read-only mode on 12/14/2017 from 12:00 am pacific to 11:30 am.
During this time you will only be able to see content. Other interactions such as posting, replying to questions, or marking content as helpful will be disabled for few hours.
We apologize for the inconvenience while we perform important updates to the Community.
Blue
Adding Responder enabled devices in IPM
Is it possible to have IPM turn on "IP SLA responder" on responder-capable devices, or would it only require enabling the responder separately outside of IPM, such as via NetConfig or manual config on IOS CLI?
1 ACCEPTED SOLUTION
Re: Adding Responder enabled devices in IPM
You would need to enable this outside of IPM as you say. Netconfig is a good way of doing this.
1 REPLY
153
