Attention: The Cisco Support Community site will be in read only mode on Dec14, 2017 from 12:01am PST to 11:30am for standard maintenance. Sorry for the inconvenience.
Adding WLSE to Ciscoworks as application
I am trying to add WLSE 2.13 as an application to my Ciscoworks. I dont know if WLSE accepts SSO (Single Signon).
Re: Adding WLSE to Ciscoworks as application
What version of CiscoWorks? How are you trying to add it? The CiscoWorks LMS/CSM/OM SSO is not compatible with the WLSE.
CW is ver 4.0.5. Anyway to have CW sso to WLSE>
The WLSE is supported by RME. You can add the WLSE to DCR as a Standard device, and RME will manage it. As for SSO, this will not work between LMS and the WLSE.
Any clues as to when SSO might be supported in WLSE?
This is not planned as the WLSE does not use Common Services.
Sorri, forgot to add that I have added it as application under Common services,Home PageAdmin
You can add the WLSE as a link on the CiscoWorks Homepage, but you cannot use the LMS SSO authentication mechanism to authenticate to the WLSE.
123
