ADSL OIDs for Max "Possible" Rate / Actual Rate
Hi, I'm trying to work out whether it is possible to retrieve via SNMP, line stats for the max upstream/downstream values.
I can retrieve the actual speeds. Also what is the defined difference between "Maximum current attainable data rate by the ATU" and "actual transmit rate"? The values returned appear to be the same, despite the actual not being the theoretical "maximum".
The specific OIDs Im using are:
1.3.6.1.2.1.10.94.1.1.2.1.8 adslAtucCurrAttainableRate
1.3.6.1.2.1.10.94.1.1.4.1.2 adslAtucChanCurrTxRate
1.3.6.1.2.1.10.94.1.1.3.1.8 adslAturCurrAttainableRate
1.3.6.1.2.1.10.94.1.1.5.1.2 adslAturChanCurrTxRate
Has anyone tried this or am I using the wrong OIDs?
Matt
324
