Webcast-Catalyst9k
After executing EEM applet, next login prompt 'corrupt'.
I have added a really simple EEM script to my routers to reset the GDOI VPN following a rekey failure. It looks like this:
event manager applet reset-gdoi
event syslog occurs 2 pattern "%CRYPTO-4-RECVD_PKT_NOT_IPSEC:"
action 1 cli command "enable"
action 2 cli command "clear crypto gdoi"
action 3 syslog msg "GDOI failure - resetting VPN"
The issue I have is that when this policy executes (perfectly sucessfully), the NEXT time I connect to the router via the VTY line I get something like this:
Username:^@
Ie the login prompt is populated with random characters!
Any ideas ?
Cheers,
Martin
1 ACCEPTED SOLUTION
Re: After executing EEM applet, next login prompt 'corrupt'.
I don't see a bug for this, but the problem is fixed in 12.4(15)T. I had noticed a similar symptom a while ago where I would get three login prompts following the execution of an applet. While I can still reproduce this using your applet in 12.4(11)T, I can no longer reproduce in 12.4(15)T. If you need a bug for, I suggest you open a TAC service request.
Please post a show ver from this device.
#sh ver
Cisco IOS Software, C180X Software (C180X-ADVIPSERVICESK9-M), Version 12.4(11)T1, RELEASE SOFTWARE (fc5)
Copyright (c) 1986-2007 by Cisco Systems, Inc.
Compiled Thu 25-Jan-07 10:15 by prod_rel_team
ROM: System Bootstrap, Version 12.3(8r)YH6, RELEASE SOFTWARE (fc1)
ar1-1999 uptime is 1 week, 1 day, 20 hours, 39 minutes
System returned to ROM by bus error at PC 0x818D80EC, address 0x818D80EC at 17:29:24 aesdt Mon Nov 19 2007
System restarted at 17:32:36 aesdt Mon Nov 19 2007
System image file is "flash:c180x-advipservicesk9-mz.124-11.T1.bin"
A summary of U.S. laws governing Cisco cryptographic products may be found at:
export@cisco.com.
Cisco 1801 (MPC8500) processor (revision 0x400) with 111616K/19456K bytes of memory.
Processor board ID FCZ101110J1, with hardware revision 0000
9 FastEthernet interfaces
1 ISDN Basic Rate interface
1 ATM interface
31360K bytes of ATA CompactFlash (Read/Write)
(I realise it is a buggy IOS, but to date has not caused us any grief :) )
Thanks for confirming the issue. At least I know I was not imagining it.
Provided the 12.4(15) release gives me full support for the GET VPN I will look at deploying it. I will definately lab it up.
In the meantime, the prospect of rolling out a new IOS to 210 routers with only 32mb of flash is daunting :)
114
