Alarm caused by ACS - Process Status threshold
Dear Team,
We are getting 2 message from ACS 5. 3 and incremental  backup  changing state to OFF in the web portal.
1. Incremental backup is not configured. Configuring incremental backup is necessary to make the database purge successful. This will help to avoid disk space issues. View database Size is 0.51GB and size it occupies on the harddisk is 0.49GB.
2. Alarm caused by ACS - Process Status threshold
Please find the attachment and help us.
Occurred At:Fri Sep 05 09:40:00 IST 2014
Cause:Alarm caused by ACS - Process Status threshold
Details:Following processes were not running between Fri Sep 05 09:38:00 IST 2014 and Fri Sep 05 09:40:00 IST 2014 for the ACS Instance(s):
ACS InstanceTimeProcesses
Name:ACS - Process Status
Description:ACS database, management and runtime process monitor
Monitored Processes:ACS Management
ACS Runtime
Monitoring and Reporting Collector
Monitoring and Reporting AlarmsManager
Monitoring and Reporting JobManager
Monitoring and Reporting LogProcessor
Filter
ACS Instance(s):acsserver
Note:ACS - Process Status
Everyone's tags (1)
276
