Alert over sms
May somebody tell me whether it's possible to configure Ciscoworks to send sms alerts based upon different user configurable network health indicators and where to find it?
Which other complementary tools could serve this purpose? Thanks.
Re: Alert over sms
Both Resource Manager Essentials and Device Fault Manager applications in CiscoWorks LMS have the ability to translate network events into email messages (RME translatest syslog messages and DFM can translate traps as well as processed network health events). If you have an email-to-SMS gateway, you can then send these messages on as SMS. However, I cannot recommend any specific third party email-to-SMS gateways.
Silver
Re: Alert over sms
If you want it low budget but good I can recommend gnokii. (gnokii.org) It comes with a daemon called smsd that can send and receive sms from and to a database.
It uses an old gsm, like most people have a couple, and a low end PC running linux.
Probably all you have to buy is a datacable.
Cheers,
Michel
121
