All VTY are busy
we have some switches (c3750) which have all VTY lines busy. We know why, because we are using a tool which works not correct. I tried the following way, but i cannot clear any of these lines. When i do a snmpwalk to tslineSesAddr i see 16 Ip-addresses. I can also do an snmpset to tsClrTtyLine for example 16 without any error. But i didnot see that the connection will cleared. I use the describtion below.
http://www.cisco.com/application/pdf/paws/45281/ttyusers2.pdf
1 REPLY
Silver
Re: All VTY are busy
Use the Commands 'clear tcp line' & 'clear line vty'
If you do not clear the VTY lines
Please verify the IOS of your switch. If 3750 running 122-40SE
This is bug CSCsm88263
Under certain conditions, a vty session may become hung and cannot be cleared
The session cannot be cleared from the device to which the tcp session was terminated.
533
