ANI server not starting
I am running Campus Manager 5.0.4.
The ANI Server is not starting. The status is "Failed to run" in the Process Management page.
I attached two log files. Tell me if you have an idea.
Julien
  • Network Management
1 ACCEPTED SOLUTION
Re: ANI server not starting
You will need to reinitialize your ANI database as it contains some bad data. To do this, run the command:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
This looks like an ani database problem. Please post the output of the pdshow command.
I attached the pdshow output.
regards,
Julien
Thanks, that solved the problem.
I need now to rediscover the network the fill the ANI database.
215
