Community Member
ANIServer Error
We recently re-deployed our CiscoWorks LMS2.2 server at a new location with a new server name. ANIServer appears to be "partially" working. Status indicates "running with busy flag set" and Campus Mgr. is able to discover devices. However, ServerConfiguration>Diagnostics>Discovery Metrics> states "ANI Server Not Running". Also ServerConfiguration>Diagnostics>Analyze ANI Server> shows "ERROR: An error occured communicating with your ANI Server [date/time]. ANI Server may not be running..." "ERROR RECEIVED - AniWrapper>>analyze(system) ServerNamed: ANIServer4.2-sestcwk1 on port 14004" "SystemInformation=unknown - ConfigurationSettings=unknown - RawAnalysis=unknown - Devices=unknown" Could these errors be caused by our renaming the CiscoWorks server? Is the new name confusing ANIServer somehow?
Thanks.
GPM
1 ACCEPTED SOLUTION
Red
Re: ANIServer Error
If you change the name of the server, you need to modify the PX_HOST entry as well in md.properties.
This is documented at the following location:
http://www.cisco.com/en/US/products/sw/cscowork/ps3996/products_user_guide_chapter09186a008017b74c.html
Red
Re: ANIServer Error
Community Member
Re: ANIServer Error
Thanks for the help. Problem solved.
113
