ANIServer issue - LMS 2.5.1 Solaris
I have just completed an upgrade (upto LMS 2.5.1) of Ciscoworks and I'm unable to access services under Campus Manager as it reports that the "ANI service is initialising". I have checked that the service is running (with pdshow) and it all looks okay.
Was wondering if anyone else has experienced this issue.
Many Thanks.
Dave
Silver
Re: ANIServer issue - LMS 2.5.1 Solaris
This can due to be a lot of things
Did you restart the deamonmanager?
Anything you see now and didn't have before in the CampusOGSServer.log, ani.log or ANIServer.log?
This is a ciscolink for troubleshooting connection problems to older versions of ANI
http://www.cisco.com/en/US/products/sw/cscowork/ps563/products_tech_note09186a0080094ec0.shtml
Since Cisco seems reluctant to create a version for Campus 4.x we should assume nothing much has changed.
Cheers,
Michel
Are you seeing any messages like java.lang.OutOfMemoryError in the ani.log?
if you just upgraded to SP4 it might be due to bug
CSCsd79426
the workaround is:
Shutdown CiscoWorks Daemon Management, then edit
NMSROOT/campus/etc/cwsi/ANIServer.properties, and change LogMsg.logfile to point to a valid file
to which casuser can write.
(Note: NMSROOT is the path to where CiscoWorks was installed. By default, this is /opt/CSCOpx
on Solaris and C:\PROGRA~1\CSCOpx on Windows.)
This has solved the problem. Many thanks guy's.
Dave
Hi Davistan
I have the same from with campus manager 4.0.3 as dave above. when i run topology services it says it cant connect to the ANIServer. i have tried the same solution as you posted above but i still have the same problem. Any other workaround on this ?
below is what i see un the log when i run topology services
log4j:ERROR No appenders could be found for category (CTM.common).
log4j:ERROR Please initialize the log4j system properly.
new instance of Ptdm create
new appId created
new appId created
Common trust user is: admin
User name in Security context is: admin
thanks in advance
Kezza
Are there any other errors in the ani.log?
What is the process status for ANIServer? have you tried stopping this process itself by pdterm/pdexec?
Also, have you done a reinit of the ani database and still seeing the same problem?
You might want to check the format of your discoverysnmp.conf file to make sure it looks ok.
Hi all
the process status was ''Running with busy flag set '', yes i did reinit the ani database, i think i did all the workaround that i could find on any forum abt this problem.
But i found a solution, i hope it will save alot of time for any other pple having the same problem after trying all the workaround. I was using firefox to browse cisco works, it didnt matter what version i was using , i still got the same problem. When i tried Microsoft Internet explorer 6.0, it worked. yes it was as simple as that after spending a whole day troubleshooting.
hope this helps someone out there not to waste alot of time .
Thanks in advance
Kezza
Firefox would be an important issue as its not a supported client browser version
IE is the only supported browser
glad its working now though!
I have the same problem with LMS 2.5.1 on Windows. The ani.log containes
"DBConnecton-Reaper ani MESSAGE DBConnection: Closed Database connection [hashCode = 6529824]
java.lang.OutOfMemoryError".
The versions are:
CiscoWorks Common Services 3.0.4
Campus Manager 4.0.5
The causer has write-permissions to ani.log
The ANIServer.properties containes:
"LogMsg.logfile=F:/PROGRA~1/CSCOpx/log\\ani.log"
The used browser-version is IE 6.0 SP2. The complete restart was done.
How many devices are you managing in Topology Services? How many end users in User Tracking? How reproducible is this error? That is, if you restart ANIServer, do you encounter the error again in a predictable amount of time? What is the output for the following command:
pdreg -l ANIServer
the system is located at a customer, and the customer has canceled yesterday the the ticket with us, because he wants not pay any money for service. Unbeleavable!
For information:
There are 170 devices dicovered, one user uses usertracking. If the customer restarts the ani-server the error occures again.
Thank you for your trouble.
Kind Regards.
Volker
I would recommend you open a TAC Service Request, then. We have been tracking some OutOfMemoryErrors with Campus Manager, and there is more debugging we need to do to track down the cause.
We will open a tac-case, if the customer does reopen the ticket.
Kind Regards
193
