11-30-2009 10:03 AM
The Ciscoworks server restated due to a power failure (UPS ran out as well), now the ANISERVER won't
start even after a clean shutdown. Does anyone know the procedure to correct this?
11-30-2009 11:57 AM
what are the implications of both methods?
11-30-2009 12:00 PM
With the restore, you will lose data in all LMS applications that was added after the backup was taken. The reinit will delete all topology and User Tracking data in Campus Manager.
11-30-2009 12:03 PM
Restore sounds like a better option.
I have a good backup from last night, I didn't do to much today!
I'll let you know what happens.
Thanks for you help.
11-30-2009 12:47 PM
The command that you included below restores the database to it's original state.
What would be the command to restore from the latest backup?
11-30-2009 12:55 PM
Check the Common Services online documentation, and search for "Restoring Data". This will provide you the steps.
11-30-2009 12:57 PM
OK
