ANIServer Running with busy flag set
We have LMS2.6/Campus manager 4.0.12
we have problem with ANI server, when I chek the status of the ANI server:
root@sec6-12 # ./pdshow ANIserver
ERROR: ANIserver is not a registered server name.Please enter a valid process/server name or check the case of the entered process/server name.
root@sec6-12 #
also in the GUI-admin-processes:
Re: ANIServer Running with busy flag set
The problem is solved by regeneration DCRserver Certification, Reninstall Java plugin
just to clarify, the error message you get is ok as the process name is ANIServer and not ANIserver (case-sensitive);
the correct process status of ANIServer is 'Running with busy flag set'; so this should have nothing to do with you original problem which I assume was a Campus Manager (Topology Service) problem.
811
