Aniserver Startup
Hello
I cannot open Topology Services because Aniserver process is down.
I haven't been able to start it. When I try, the process seems to be busy for a while but finally It fais
The instructions shown in other similiar cases havent' worked for me.
Everyone's tags (2)
1 ACCEPTED SOLUTION
Re: Aniserver Startup
you can try to reinit the topology part of the ANI database to solve this issue; you will loose all your customized maps;
the command to reinitialzie the topology portion of the ANI database:
NMSROOT\bin\perl NMSROOT\campus\bin\reinitdb.pl
with NMSROOT being you LMS installation path (default for windows: C:\Progra~1\CSCOpx)
after that start a new Data Collectio (Campus > Home) and see if the problem has gone;
post the complete output of pdshow.
it seems there are some device inconsistencies.
It works!
Thank you
418
