10-16-2006 05:12 AM
Hi all,
Running Cworks LMS 2.6 w/ CM 4.0.7. DeviceDiscovery is not starting up, immediating failing after attempting a discovery. The following is the error I've gotten in the log:
2006/10/16 09:01:34 main DiscoveryMain: Loading mib values...complete
2006/10/16 09:01:34 main DiscoveryMain: Loading communities values...complete
2006/10/16 09:01:34 main ERROR DiscoveryMain: AniStaticConfigException: Time base name Devdiscovery not not valid for SMFDefinition com.cisco.nm.ani.server.devdiscovery.DevdiscoverySMFCreateSeedDevice
Has anyone else come across this error? If so, what was the resolution?
Solved! Go to Solution.
10-16-2006 08:20 AM
Don't remove anything. The first example above is fine. Order is really unimportant in these files.
10-16-2006 05:19 AM
have a look at your DeviceDiscovery.properties file and check for the following entry:
DEVICESROOT=
DEVICESPACKAGE=com.cisco.nm.ani.server.devices
DeviceConfigFile=devices.xml
If it is this way above, it needs to be changed to:
DEVICESROOT=D:\\CSCOpx\\campus\\lib\\classpath
Also, if this does not work you may want to contact the TAC as you could have a corrupted DevdiscoverySMFEnd.class file
10-16-2006 07:56 AM
Looks about the same. I've got a TAC case open but was wondering if others had a similar problem.
# Device factory properties
DEVICESROOT=C:\\PROGRA~1\\CSCOpx\\campus\\lib\\classpath
10-16-2006 07:33 AM
Look at NMSROOT/campus/etc/cwsi/DeviceDiscovery.properties, and look for lines that being with TimeBase. There should be three. Something like:
TimeBase.Devdiscovery.Type=Periodic
TimeBase.Devdiscovery.Schedule=1073741823
TimeBase.Devdiscovery.ThreadPool=Devdiscovery
10-16-2006 08:00 AM
Hmm. What I have is a bit different. Could this be a new format for the file with w/ LMS 2.6 being installed?
# Thread
ThreadPool.Devdiscovery.priority=HIGH
ThreadPool.Devdiscovery.count=48
10-16-2006 08:06 AM
No, this is wrong. Add the following two lines, and you'll be set:
10-16-2006 08:17 AM
Before I pop these in, do I add these lines before what's already there so it becomes:
# Thread
Or do I remove the ThreadPool.Devdiscovery lines and have it just like this:
# Thread
10-16-2006 08:20 AM
10-16-2006 08:41 AM
Thanks! Discovery is back up and running.
Dave
