ANM Linux 64 bit
Hi all,
Is it absolutely necessary to use a 32-bit RedHat 5.2?
What's the reason for this, is it because of 32bit kernel-modules are
loaded?
If it isn't because of 32bit kernel-modules, can you use a 64-bit RedHat
with 32-bit compatability libraries in order to satisfy the ANM 2.0
dependencies?
In case you can use 32-bit libraries for compatability, which libraries
are required?
Mats
1 REPLY
Silver
Re: ANM Linux 64 bit
Cisco Application Network Manager will support only 32-bit Linux. It won't support 64-bit.
123
