Community Member
Apache and tomcat errors in LMS
We have a LMS 3.1 which show some errors in event viewer of Windows SO. I attach these errors.
What these errors mean?
Community Member
Re: Apache and tomcat errors in LMS
I attach errors
These errors are caused by an integration bug between Apache and mod_ssl. Many customers see these (including us in our own lab), however, they are mostly harmless. Some customers report that when this occurs, Apache is no longer usable until Daemon Manager is restarted. In either event, these errors no longer occur in LMS 3.2.
Community Member
Thanks jclarke, but
How can I fix it in version 3.1?
There is no fix for 3.1. If you are seeing actual functionality impact, then I suggest you upgrade to 3.2. Most customers do not see any functionality impact, and simply ignore the errors.
Community Member
Thank you very much joe
212
