Apache Server for MRTG operrarion !
Hi !
I have installed snmp,mrtg and apache server1.3.37 also.
Apache operartion is ok (The test page appears when I type "http://172.25.7.107/" from other PC)
But I still can't see mrtg pages from other PCs, for example:"http://172.25.7.107/mrtg/l2sw01.html"
I think need to link mrtg folder, or some thing..., but I don't know how to do that
Pls help me to solve this problem!
Thanks a lot !
Re: Apache Server for MRTG operrarion !
Check the "Alias" keyword in the apache documentation.
Alias /mrtg /opt/mymrtginstallation
Can you show more detail?
I tested Apache from another PC by browse "Apache Test Page": http://172.25.7.107/ ,and it is OK!
Thank you very much!
Silver
the alias command is to map /mrtg/ to a directory where mrtg puts it's html files.
You have to alter the httpd.conf and restart the apache service.
Look for alias in the apache doc's
Cheers,
Michel
Bronze
Copy the mrtg folder into the apache webserver www folder if linux or htdocs if windows installation.
now try http://172.25.7.107/mrtg
Can u tell me ur Operating system which is running apache server.
Hope this helps
Raj
Yes.
I'm using Fedora Core 5
I have added: Alias /mrtg "/var/www/mrtg/" to httpd.cfg file, and change /var/www/mrtg/l2sw01.html permission to "wrx" for all people. But when I connect to http://172.25.7.107/mrtg/l2sw01.html from another PC, still apear message: "You don't have permission to access /mrtg/l2sw01.html on this server."
Pls help me!
Thanks a lot!!!
147
