application: sends,receieves packets and logs everything with time
hi all
I need a tool which is able to send TCP/UDP/IGMP , and receieve on remote pc, log the activities with time.
if communication is cut then become alive again (like STP steps until forwarding), i need to log the packet delivery failure time in the scale of miliseconds.
anybody used such an application?
all advices will be appreciated
tx a lot in advance for helping
  • Network Management
Re: application: sends,receieves packets and logs everything wit
with a cisco router you could use SAA (service assurance agent). It will send defined packets to configured destinations at a rate configured. You can obtain the statistics and failures through SNMP and/or CLI.
For a full description of capabilities have a look at "Network Monitoring Using Cisco Service Assurance Agent"
http://www.cisco.com/en/US/products/sw/iosswrel/ps1835/products_configuration_guide_chapter09186a008030c773.html
In case you want a solely PC based solution have a look at "Network Monitoring" http://www.netmon.org/tools.htm
There are a couple of tools (even freeware) which should be helpful.
Hope this helps! Please rate all posts.
Regards, Martin
thanks a lot Martin,
I read the document, SAA looks just what I am looking for but unfortunately it seems SAA works well for routers but not for switches :( I am gonna use the stuff for 4506 switches.
I hope netmon.org will be my last stop :)
greetings
92
