Community Member
Archive amanagement in RME
I get the following error in trying to fetch files in Archive management.
"Execution status: job execution partially successful for device.
Execution message: config fetch is successful using rcp.cm0060 primary startup config fetch success for device, version number 1 archived.config fetch is successful using rcp. Cm0061 primary running config fetch success for device, no change in configuration cm0151. VLAN running config fetch failed for device; failed to fetch config using rcp."
Where did i go wrong or what have i missed in the configuration?
Thank You and Kind Regards,
GT.
1 ACCEPTED SOLUTION
Silver
Re: Archive amanagement in RME
Under RME-Admin-Config Mgmt-Transport settings do you have the protocols that are configured on your device set up and in the order that you want them to be used ?
Silver
Community Member
Thank you for your assistance.
Yes i do have the list of protocols in place. In fact i did try setting only TFTP for one device and tried to run the archive management for the specific devcie and i get the same error.
Thanks again!
Community Member
Thank You for your time and assistance, i have solved the prolem which was related to the order of transport protocol setting.
Thank You again!
151
