Community Member
Archive issue
I have checked with other devices also. In some devices I am getting failed message and in some jobs I am getting partially successfully. Please find the attachment.
Vaibhav
Re: Archive issue
This doesn't say much. What version of RME are you using? What type of devices are each of these? What are the details found when you click on "Failed" or "Partially Successful"?
Community Member
Re: Archive issue
Version of RME is 4.0.5 please find the attachment. Type of device is catalyst 4503
I am attaching the snap shot of the details I got when I click on the partially successful and failed, please find the attachment
Vaibhav
Re: Archive issue
The failed device messages point to incorrect credentials in DCR for this device. Export the DCR credentials for this device under Common Services > Device and Credentials > Device Management, and verify you can login with those credentials from the server.
The same is true for the partially successful device. The username/password credentials in DCR appear to be wrong.
109
