Archive Management Jobs Failed
Good momrning,
I have launch immediate archive from RME.
But, my "Archive Management Jobs" sucks in "Failed mode" most of my devices are partially successful and no one are ok.
Many thanks in advance
Olivier
Here is the status of my Collection status home page ????
Collection Status
Operation Devices : Status
Inventory 90 : Success
11 : Failed
Config Archive 0 : Success
17 : Failed
84 : Partially Successful
91 : Out-of-Sync
Re: Archive Management Jobs Failed
Resource Manager Essentials Home
Auto Refresh Version : 4.0.5 Last Updated: 07 Feb 2007, 10:55:54 WAT
Device Management Status
Device State Number of Devices
Normal 101
Pending 0
Pre-deployed 0
Suspended 0
Alias 0
Conflicting 0
Total Number of Devices 101
Collection Status
11 : Failed
17 : Failed
91 : Out-of-Sync
Recently Completed Jobs
Job Id Job Type Status Description Completed At
1013 CDA Failure LAN/WAN TEP CG Feb 07 2007 10:49:39
1014 Inventory Collection Failure LAN/WAN TEP CG Feb 07 2007 10:48:12
1010 ArchiveMgmt Failure Sync Archive Feb 07 2007 10:30:44
1012 ArchiveMgmt Failure LAN PKR Feb 07 2007 10:30:00
1009 ArchiveMgmt Failure LAN BI Feb 07 2007 10:28:09
More..
24 Hour Syslog Severity Summary
Operation Status
Emergencies 0
Alerts 0
Critical 0
24 Hour Changes
Operation Status
Inventory Change 88
Config Change 78
Why do they fail what is the error reason to why the fail ? Network access, failure to logon to the machine etc?
Here is the description i can see in RME after doing sync Archive:
CM0208 User not authorised to perform operations on device
CM0002: Could not archive config Cause: Device may not be reachable, may be in suspended state or credentials may be incorrect. Action: Verify that device is managed, credentials are correct and file system has correct permissions. Increase timeout value, if required.
I am also unable to look at raw configs or do a comparison between running and startup configs in RME. I keep getting an error message CM0208 User not authorized to perform operations on device.
I tried increasing timeout (snmp, telnet and tftp), credentials are OK. i tried also to delete and rediscover the devices (adding all devices manually) but no luck.
Any thoughts?
136
